  • Diverse ports, four service slots, up to 128 x 100GE QSFP28 ports or 64 x 100GE QSFP28 and 16 x 400GE QSFP-DD ports
Various ports, up to 128 x 100GE ports or 64 x 100GE ports and 16 x 400GE ports, which are fit for different scenarios of data center networks
and Zero Packet Loss
RG-S6920-4C
100GE/400GE ports
Four expansion modules, with each module supporting 32 × 100GE ports
Expansion Slots
Six fan module slots
25.6 Tbps
8000 Mpps
4094
RG-S6920-4C
(W × D × H)
442 mm × 173.5 mm × 735 mm, 4 RU
About 43.5 kg (including all line cards, power supply modules, and fans)
RG-S6920-4C
Maximum Power Consumption
1950 W
AC
Rated voltage range: 100 VAC to 240 VAC, 50 Hz to 60 Hz
Maximum voltage range: 90 VAC to 264 VAC, 50 Hz to 60 Hz
High-voltage DC
Input voltage range: 192 VDC to 288 VDC
RG-S6920-4C
0°C to 40°C
10% to 90% RH (Non-condensing)
RG-S6920-4C
L2 Protocols
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and selective QinQ), GVRP
L3 Protocols (IPv4)
IPv6 Basic Protocols
Data Center Features
M-LAG
RDMA
OpenFlow 1.3
sFLOW sampling
INT
HA Design
Security Features
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, ARP spoofing prevention, ARP check, and hierarchical user management
Management Mode
SNMP v1/v2/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm function, temperature alarm function, and configuration rollback
The configuration procedure for the RG-S6920-4C switch is as follows:
● Select the switch.
● Select expansion modulesbased on business requirements.
● Select the fan and power supply modules.
● Select Optical Transceivers based on port requirements.
RG-S6920-4C
Four expansion slots, four power supply module slots, and six fan module slots
The power supply module model is RG-PA1200I-F and the fan model is M2EFAN I-F.
RG-PA1200I-F
Power supply module, supporting 2+2 redundancy, hot swapping, and front-to-rear ventilation design
M2EFAN I-F
Fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design
M6900-32CQ
32 x 100GE ports
M6900-16CQ4QC
16 × 100GE optical ports (QSFP28) + 4 × 400GE optical ports (QSFP-DD)
