RG-S6980-64QC Commutateurs - 1
RG-S6980-64QC Commutateurs - 2
RG-S6980-64QC Commutateurs - 3
RG-S6980-64QC Commutateurs - 4
RG-S6980-64QC Commutateurs - 5
RG-S6980-64QC Commutateurs - 6
RG-S6980-64QC Commutateurs - 7
RG-S6980-64QC Commutateurs - 8
RG-S6980-64QC Commutateurs - 9
RG-S6980-64QC Commutateurs - 10
RG-S6980-64QC – 64-Port 400GE Data Center Core Switch, 4 RU
  • High-density 400GE switch with 64 x 400GE QSFP-DD ports in the 4-RU space
  • 400GE QSFP-DD ports, interconnection at the distance of up to 120 km, and smooth and rapid data communication
Data Center 400GE Core Switch RG-S6980-64QC
High-speed and high-density core switch in a data center with 64 x 400GE QSFP-DD ports in the 4 RU space, delivering scalable,
high-performance and high-bandwidth services and coping with interconnection on a large data center network
IPv4/IPv6 Host Routing Entries
1000K/640K
Buffer
113.66MB
400GE ZR/ZR+ optical modules are used for interconnection reducing intermediate transmission devices and helping a cloud or hyper-scale
data center network to adapt to growing high-bandwidth services.
and Zero Packet Loss
RG-S6980-64QC
64 × 400GE ports (QSFP-DD), up to 128 x 200GE ports
Expansion Module Slots
Eight fan module slots
51.2 Tbps
10,300 Mpps
4,094
Dimensions (W × D × H)
442 mm x 760 mm x 175 mm (17.40 in. x 29.92 in. x 6.89 in., 4 RU)
38 kg (83.78 lbs., including eight fan modules and four power supply modules)
● Max: 2,400 W
● Typical: 1,760 W
● Static: 500 W
AC
Rated voltage range: 100 V AC to 127 V AC
Frequency: 50 Hz to 60 Hz
Maximum rated input current: 13.8 A
Rated voltage range: 200 V AC to 240 V AC
Maximum rated input current: 8.5 A
High-Voltage DC
HVDC input: 180 V DC to 300 V DC
Rated voltage: 240 V DC
Rated input current: 6.5 A
RG-S6980-64QC
Layer 3 Protocols (IPv4)
BGP4, OSPFv2, RIPv1, RIPv2, LPM routing, PBR, routing policy, ECMP, WCMP, VRRP
IPv6 Protocols
Data Center Features
PFC, ECN
RDMA
VXLAN, BGP-EVPN
PFC deadlock prevention
* AI ECN
* ECN overlay
RALB, AILB
802.1p, DSCP, and ToS mapping
Hgh Availability Design
GR for RIP/OSPF/BGP, BFD, DLDP, REUP dual-link fast switching, RLDP unidirectional link detection, 2+2 power redundancy and fan redundancy, and hot swappable line cards and power modules
Security Features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, broadcast packet suppression, hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and overheat alarm
DHCP client, DHCP relay, DHCP server, DNS client, proxy ARP, and Syslog
Specification
RG-S6980-64QC
● BS EN 62368-1
● EN 61000-3-2
● BS EN55032
● BS EN 55035
● BS EN 61000-3-2
● BS EN 61000-3-3
● EN 300 386
RG-S6980-64QC
64 x 400GE ports, four power supply module slots, eight fan slots
RG-PA1200I-F
M2EFAN II-F
400G-QDD-SR8-MM850
400G-QDD-FR4-SM1310
400G FR4 transceiver, QSFP-DD form factor, Duplex
LC, 1310 nm, 2 km (6,561.68 ft.) over SMF
400G-QDD-DR4-SM1310
*400G-QDD-ZR-SM1550
400G ZR transceiver, QSFP-DD form factor, LC, tunable wavelength, P2P distance of up to 80 km (262,467.19 ft.) over SMF
* in Ordering Information indicates that the product will be available in the future.
