RG-S6510-4C |
Ports |
25GE, 40GE, and 100GE ports |
Slots |
4 |
Expansion Modules |
M6500-24VS2CQ, M6500-08CQ, M6500-16QXS |
Expansion Module Slots |
Management Port |
Switching Capacity |
6.4 Tbps |
Packet Forwarding Rate |
2030 Mpps |
802.1Q VLAN |
4094 |
RG-S6510-4C |
Dimensions |
442 mm × 520 mm × 86 mm (2 RU) |
About 19 kg (including power supply modules and fan modules) |
RG-S6510-4C |
AC |
Rated voltage range: 100 VAC to 240 VAC, 50 Hz to 60 Hz Maximum voltage range: 90 VAC to 264 VAC, 50 Hz to 60 Hz Rated input current: 5 A to 10 A |
High-voltage DC |
Input voltage range: 192 VDC to 288 VDC Input current range: < 4.5 A |
Maximum Power Consumption |
< 650 W |
RG-S6510-4C |
Operating Temperature |
0°C to 40°C |
Operating Humidity |
Software Specifications |
RG-S6510-4C |
L2 Protocols |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
Data Center Features |
VXLAN routing and VXLAN bridging EVPN VXLAN IPv6 VXLAN over IPv4 PFC, ECN, and other data center features RDMA M-LAG OpenFlow 1.3 |
Visualization |
gRPC sFLOW sampling INT |
QoS |
Virtualization |
Virtual Switching Unit |
Cache Management |
Cache status monitoring and management, and identification of burst traffic |
HA Design |
GR for RIP/OSPF/BGP, BFD, REUP dual-link fast switching and RLDP unidirectional link detection, 1+1 power redundancy, and fan redundancy, and hot swapping for all cards and power supply modules |
Security Features |
Network Foundation Protection Policy (NFPP), CPP, DDoS attack defense, illegitimate data packet detection, data encryption, source IP spoofing prevention, IP scanning prevention, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, RIPv2, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, uRPF, broadcast packet suppression, DHCP Snooping, gateway ARP spoofing prevention, and ARP check |
Management Mode |
SNMP v1/v2/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN, Telemetry, ZTP, Python, fan and power supply alarm, and temperature alarm |
Other Protocols |
● Select the switch, fan, and power supply modules.
● Select expansionmodules based on port
● Select optical transceivers.
Product Model |
RG-S6510-4C |
Four expansion module slots, supporting hot swapping. |
RG-PA800I-F |
M6500-FAN-F |
Product Model |
M6500-08CQ |
Eight QSFP28 ports The QSFP28 port supports a speed of 40 Gbps/100 Gbps. |
M6500-24VS2CQ |
24 25GE SFP28 ports and two QSFP28 ports SFP28 supports a speed of 10G/25G rates. The QSFP28 port supports a speed of 40 Gbps/100 Gbps. One QSFP port can be split into four 10GE or 25GE ports. |
M6500-16QXS |
16 QSFP ports |
Product Model |
100G-QSFP-SR-MM850 |
100GE SR optical transceiver, QSFP28 package, MPO connector (850 nm wavelength) |
100G-QSFP-LR4-SM1310 |
100GE LR single-mode optical transceiver, QSFP28 package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), maximum transmission distance of 10 km |
100G-QSFP-iLR4-SM1310 |
100GE iLR optical transceiver, QSFP28 package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), maximum transmission distance of 2 km |
Product Model |
40G-QSFP-SR-MM850 |
40GE SR optical transceiver, QSFP+ package, MPO connector (used in combination with OM3/OM4 MPO optical fibers, 8-core/12-core, 850 nm wavelength) |
40G-QSFP-LR4-SM1310 |
40GE LR optical transceivers, QSFP+ package, LC connector (used in combination with LC optical fibers, 2-core, 1310 nm wavelength), maximum transmission distance of 10 km |
40G-QSFP-LSR-MM850 |
40GE SR optical transceivers, QSFP+ package, MPO connector (used in combination with OM3/OM4 MPO optical fibers, 8-core/12-core, 850 nm wavelength) |
Product Model |
VG-SFP-SR-SM850 |
25GE SR optical transceiver, SFP28 package, LC connector, and 850 nm wavelength |
VG-SFP-LR-SM1310 |
25GE LR optical transceiver, SFP28 package, LC connector, and 1310 nm wavelength |
