24-Port GE Optical Ports (with Eight Combo Ports), 8 × 10G Optical Ports
RG-CS85-24GT8XS-D24 x GE Electrical Ports, 8 x 10GE Optical Ports
RG-CS85-48GT4XS-D48-Port GE Electrical Ports,4 × 10G Optical Ports
RG-CS85-48SFP4XS-D48-Port GE Optical Ports, 4 × 10G Optical Ports
RG-CS85-48GT4XS-HPD48-Port GE Electrical Ports, 4 × 10G Optical Ports, PoE/PoE+
RG-CS85-24GT8XS-D |
RG-CS85-24SFP/8GT8XS-D |
RG-CS85-48GT4XS-D |
RG-CS85-48GT4XS-HPD |
RG-CS85-48SFP4XS-D |
Fixed port |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports |
24 x 1000 Mbps SFP ports (ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, PoE/PoE+ supported, 4 x 1GE/10GE SFP+ ports |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports |
Fan module |
3 fixed fans |
3 fixed fans |
3 fixed fans |
2 modular fans |
3 modular fans |
Power module |
Fixed management port |
1 x console, 1 x MGMT, 1 x USB3.0 |
Expansion slot |
One expansion slot |
Packet forwarding rate |
512 Mpps |
512 Mpps |
488 Mpps |
488 Mpps |
488 Mpps |
Switching capacity |
688 Gbps |
688 Gbps |
656 Gbps |
656 Gbps |
656 Gbps |
MAC address table size |
64,000 |
64,000 |
64,000 |
64,000 |
64,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
4,000 |
4,000 |
4,000 |
4,000 |
4,000 |
14,000 |
14,000 |
14,000 |
14,000 |
14,000 |
2,000 |
2,000 |
2,000 |
2,000 |
2,000 |
Ingress: 7,000 Egress:1,500 |
Number of VSU members |
4 |
4 |
4 |
4 |
4 |
440 x 340 x 44 mm (17.32 x 13.39 x 1.73 in), 1 RU |
442 x 420 x 43.6 mm (17.40 x 16.54 x 1.72 in), 1 RU |
4.4 kg (9.70 lbs) |
4.3 kg (9.48 lbs) |
4.5 kg (9.92 lbs) |
5.5 kg (12.12 lbs) |
5.3 kg (11.68 lbs) |
Dual-core CPU, 1.2 GHz |
Flash memory |
4 GB |
4 GB |
4 GB |
4 GB |
4 GB |
BootROM |
16 MB |
16 MB |
16 MB |
16 MB |
16 MB |
SDRAM |
1 GB |
1 GB |
1 GB |
1 GB |
1 GB |
Data packet buffer |
4 MB |
Power and Consumption |
<60 W (excluding expansion modules) |
<77 W (excluding expansion modules) |
<70 W (excluding expansion modules) |
<110 W (non-PoE) <1,590 W (PoE full load) |
<150 W |
Maximum output power |
RG-PA150IB-F: 150 W |
RG-PA600I-P-F: 600 W RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000 W 90 V AC to 176 V AC, 930 W (PoE: 740 W) |
Rated input voltage |
AC: 100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V |
AC: 200 V to 240 V
DC: -48 V to -60 V |
AC: 100 V to 240 V DC: -48 V to -60 V |
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V |
AC: 176 V to 264 V
DC: -38 V to -75 V |
AC: 90 V to 264 V
DC: -36 V to -75 V |
≥ 1,051,000 hours |
≥ 823,000 hours |
≥ 963,000 hours |
≥ 832,000 hours |
≥ 788,000 hours |
Primary Airflow |
Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) |
Operating noise |
45°C: 56.2 dB |
45°C: 57.1 dB |
45°C: 57.9 dB |
27°C: 50 dB 45°C: 65 dB |
27°C: 53 dB 45°C: 68 dB |
Interface surge protection |
RG-CS85 Series |
Feature |
Ethernet switching |
Super VLAN, Private VLAN |
Basic QinQ Flexible QinQ |
STP, RSTP, and MSTP |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP routing |
BGP4 and BGP4+ |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
MPLS |
MPLS L3VPN |
Port traffic rate limiting |
Multiple AAA modes |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
Global IP-MAC binding |
SAVI |
REUP, RLDP, DLDP |
BFD |
SPAN, RSPAN, and ERSPAN |
sFLOW |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
Cloud and SON |
RG-CS85-24GT8XS-D |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
24 x 10/100/1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
RG-CS85-48GT4XS-D |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.) |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
CM85-4XS2CQ |
Expansion module, 4 x 10GE SFP+ ports and 2 x 100GE QSFP28 ports |
RG-PA150IB-F |
150 W AC power supply module |
RG-PA600I-P-F |
600 W PoE AC power supply module |
RG-PA1000I-P-F |
1000 W PoE AC power supply module |
Single-port 1000BASE-LH mini GBIC module (LC interface), supporting a transmission distance of 40 km (24.85 miles) |
MINI-GBIC-ZX50-SM1550 |
Single-port 1000BASE-ZX mini GBIC module (LC interface), supporting a transmission distance of 50 km (24.85 miles) |
Single-port 1000BASE-ZX mini GBIC module (LC interface), supporting a transmission distance of 80 km (24.85 miles) |
MINI-GBIC-ZX100-SM1550 |
10GE LC module (62.5/125μm: 33 m (108.27 ft); 50/125μm: 66 m (216.54 ft); transmit for 300 m (984.25 ft) when modal bandwidth is 2000Mhz *km), applicable to SFP+ ports |
10GE SFP+ fiber-optic cable, 1 m (3.28 ft), including one cable and two interface modules |
10GE SFP+ fiber-optic cable, 3 m (3.28 ft), including one cable and two interface modules |
10GE SFP+ fiber-optic cable, 5 m (3.28 ft), including one cable and two interface modules |
