RG-S7620-20SFG2CQ Commutateurs - 1
RG-S7620-20SFG2CQ Commutateurs - 2
RG-S7620-20SFG2CQ Commutateurs - 3
RG-S7620-20SFG2CQ Commutateurs - 4
RG-S7620-20SFG2CQ Commutateurs - 5
RG-S7620-20SFG2CQ Commutateurs - 6
RG-S7620-20SFG2CQ Commutateurs - 7
RG-S7620-20SFG2CQ Commutateurs - 8
RG-S7620-20SFG2CQ Commutateurs - 9
RG-S7620-20SFG2CQ Commutateurs - 10
RG-S7620-20SFG2CQ Commutateurs - 11
  • Twenty SFG ports (equivalent to 160 SFP channels) and two 100G uplink ports, backward compatible with 40G, and allowing flexible configuration
Twenty SFG hyper-converged ports are provided with each supporting up to eight SFP channels. This supports connections for up to 160 devices simultaneously. High-density connections can be established in this 2 U switch, and two 100G QSFP28 uplinks and one expansion slot for connecting devices such as servers and regular switches are available to support diversified configurations.
and High Performance
Hot-swappable Redundant Power
Hot-swappable Redundant Fan
Quick onboarding
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Fan module slot
Power module slot
2 (1+1 redundancy)
2 (1+1 redundancy)
2 (1+1 redundancy)
2 (1+1 redundancy)
714 Mpps
1786 Mpps
833 Mpps
2976 Mpps
960 Gbps
2.4 Tbps
1.12 Tbps
4 Tbps
128,000
128,000
128,000
128,000
96,000
96,000
96,000
96,000
4000
65,000
65,000
65,000
65,000
Ingress: 28,000
Egress: 4,000
Weight (full configuration)
CPU and Memory
2.2 GHz quad-core processor
Memory and storage
Flash memory: 16 GB
BootROM: 16 MB
Flash memory: 16 GB
BootROM: 16 MB
Flash memory: 16 GB
BootROM: 16 MB
Flash memory: 16 GB
BootROM: 16 MB
< 300 W
< 300 W
< 450 W
< 450 W
RG-PA550I II-F: 550 W
RG-PA550I II-F:
HVDC input: 240 V DC
RG-PA550I II-F:
0°C to 45°C (32°F to 113°F)
5% to 90% RH (non-condensing)
Device Model
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IP service
Static ARP
GRE tunnel
IPv4/IPv6 static routing
Graceful restart (GR)
IPv4 IS-IS
IPv6 IS-IS
PIM-SM
PIM-DM
Port-based rate limiting
RSPAN and ERSPAN
FTP and S TFTP
VLAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
VXLAN EVPN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
RG-PA550I II-F
550 W AC power module
M7600-2CQ
M7600-4GT4VS
