RG-S5350-24GT4SFP-E24 x 1GE RJ45 ports, 4 x 1GE SFP ports
RG-S5350-24GT4SFP-P-E24 x 1GE RJ45 ports, 4 x 1GE SFP ports, PoE+
RG-S5350-48GT4SFP-E48 x 1GE RJ45 ports, 4 x 1GE SFP ports
RG-S5350-48GT4SFP-P-E48 x 1GE RJ45 ports, 4 x 1GE SFP ports, PoE+
Port Specifications |
RG-S5350-24GT4XS-E |
RG-S5350-48GT4XS-E |
RG-S5350-12GT4XS-P-E |
RG-S5350-24GT4XS-P-E |
RG-S5350-48GT4XS-P-E |
Fixed service ports |
Fixed management port |
1 x RJ45 console port |
USB |
1 x USB 2.0 port |
USB hot swapping |
Supported |
Cable hot swapping |
Supported by all ports |
115 Mpps |
158 Mpps |
94 Mpps |
115 Mpps |
158 Mpps |
154 Gbps |
211 Gbps |
125 Gbps |
154 Gbps |
211 Gbps |
Switch buffer |
4 MB |
Real-time clock (RTC) |
Supported |
BootROM |
16 MB |
Flash memory |
512 MB |
Memory |
DDR4 1GB |
Switch buffer |
4 MB |
MAC address table size |
16,000 |
4,000 |
6,000 |
1,000 |
2,000 |
750 |
Ingress: 1,750 Egress: 800 |
Number of VSU members |
4 |
Unit dimensions (W x D x H) |
Rack height |
1 RU |
Unit weight |
3.1 kg (6.83 lbs) |
3.25 kg (7.17 lbs) |
3.3 kg (7.28 lbs) |
3.4 kg (7.50 lbs) |
4.0 kg (8.82 lbs) |
Mounting |
Power supply |
1 x fixed power supply |
Power input |
Maximum output power |
Fixed power supply: 25 W |
Fixed power supply: 40 W |
25 W |
40 W |
Leakage current |
≤ 3.5 mA |
Energy saving |
Supported |
Power supply |
Power input |
Leakage current |
≤ 3.5 mA |
PoE port |
PoE power cable pairs |
Mode A (1-2, 3-6 pairs) |
PoE output power |
Energy saving |
supported |
Temperature |
Humidity |
Altitude |
Fan |
No fan |
1 x fixed fan module |
Heat dissipation |
Acoustic noise |
Fanless, quiet, < 20 dB |
27℃(80.6°F): 32 dB |
27℃(80.6°F): 35 dB |
Fan monitoring |
Fanless design |
Temperature monitoring |
Supported |
ESD |
Surge protection |
RG-S5350-E Series |
Feature |
Ethernet switching |
802.3az EEE |
IEEE 802.1Q (4K VLANs) |
Super-VLAN and private VLAN |
Basic QinQ Selective QinQ |
IP service |
DHCP snooping |
DHCPv6 snooping |
IP routing |
OSPFv2 and OSPFv3 |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
PIM SMv6, and PIM-SSMv6 |
MSDP |
MLDv1/v2 and MLD proxy |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
Multicast querier |
Global ACLs |
Multiple AAA modes |
RADIUS and TACAS+ |
HTTPS |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMPv6 |
SAVI |
ARP spoofing prevention |
Broadcast storm suppression |
BPDU guard |
Port protection |
REUP |
RLDP |
DLDP |
BFD, NSR, VRRR, VRRP+ |
Basic LACP |
Dual-Boot Redundancy |
SPAN, RSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2c/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
CWMP (TR-069) |
CLI (Telnet/Console) |
Web |
Syslog/Debug |
RG-S5350-12GT4XS-P-E, RG-S5350-E-24GT4XS-P-E, and RG-S5350-E-48GT4XS-P-E IEEE 802.3af and 802.3at Warm start Port priority Automatic and energy-saving power supply management modes Uninterrupted power supply in hot start mode Scheduled power-on or power-off of PoE ports based on the time policy |
MINI-GBIC-ZX50-SM1550 |
MINI-GBIC-ZX100-SM1550 |
GE-SFP-LX03-SM1310-BIDI-I |
GE-SFP-LX03-SM1550-BIDI-I |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
2.5G-SFP-LX03-SM1310-BIDI-I |
2.5G-SFP-LX03-SM1550-BIDI-I |
XG-SFP-ZR-SM1550 |
XG-SFP-LR10-SM1270-BIDI-I |
XG-SFP-LR10-SM1330-BIDI-I |
