48 x GE RJ45 Ports, 4 x 2.5 GE SFP Ports
RG-S5000-24GT4MS-P-E24 x GE PoE+ Ports, 4 x 2.5 GE SFP Ports, 370 W
RG-S5000-24GT4MS-E24 x GE RJ45 Ports, 4 x 2.5 GE SFP Ports
RG-S5000-10GT2MS-P-E8 x GE PoE+ Ports, 2 x 2.5 GE SFP Ports, 125 W
RG-S5000-10GT2MS-E10 x GE RJ45 Ports, 2 x 2.5 GE SFP Ports
Port specifications |
RG-S5000-10GT2MS-E |
RG-S5000-24GT4MS-E |
RG-S5000-48GT4MS-E |
RG-S5000-10GT2MS-P-E |
RG-S5000-24GT4MS-P-E |
Fixed service port |
10 x 10/100/1000BASE-T ports 2 x 1GE/2.5GE SFP ports |
24 x 10/100/1000BASE-T ports 4 x 1GE/2.5GE SFP ports |
48 x 10/100/1000BASE-T ports 4 x 1GE/2.5GE SFP ports |
10 x 10/100/1000BASE-T ports, ports 1 to 8 supporting PoE/PoE+ 2 x 1GE/2.5GE SFP ports |
24 x 10/100/1000BASE-T ports, supporting PoE/PoE+ 4 x 1GE/2.5GE SFP ports |
Fixed management port |
1 x RJ45 console port |
USB |
1 x USB port |
27 Mpps |
61 Mpps |
104 Mpps |
27 Mpps |
61 Mpps |
36 Gbps |
82 Gbps |
139 Gbps |
36 Gbps |
82 Gbps |
Single-core CPU, with the clock speed of 1.2 GHz |
Flash memory |
64 MB |
64 MB |
64 MB |
64 MB |
64 MB |
Memory |
DDR4 512 MB |
DDR4 512 MB |
DDR4 512 MB |
DDR4 512 MB |
DDR4 512 MB |
Switch buffer |
512 KB |
512 KB |
512 KB |
512 KB |
512 KB |
MAC address |
16000 |
512 |
ND table size |
256 |
64 |
64 |
500 |
Dimensions and weight |
Unit dimensions (W x D x H) |
260 mm x 170 mm x 43.6 mm (10.24 in. x 6.69 in. x 1.72 in.) |
440 mm x 220 mm x 43.6 mm (17.32 in. x 8.66 in. x 1.72 in.) |
297 mm x 170 mm x 43.6 mm (11.69 in. x 6.69 in. x 1.72 in.) |
485 mm x 410 mm x 390 mm (19.04 in. x 16.14 in. x 15.35 in.) |
570 mm x 490 mm x 390 mm (22.44 in. x 19.29 in. x 15.35 in.) |
580 mm x 450 mm x 380 mm (22.83 in. x 17.72 in. x 14.96 in.) |
Rack height |
1 RU |
1 RU |
1 RU |
1 RU |
1 RU |
Unit weight |
2.0 kg (4.41 lbs) |
2.5 kg (5.51 lbs) |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
2.8 kg (6.17 lbs) |
Shipping weight |
2.40 kg (5.25 lbs) |
3.70 kg (8.15 lbs) |
3.60 kg (7.94 lbs) |
3.18 kg (7.01 lbs) |
4.13 kg (9.11 lbs) |
Mounting |
Power supply and consumption |
Power supply |
1 x fixed power supply |
Power input |
AC input ● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz ● Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz ● Maximum input current: 0.6 A |
AC input ● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz ● Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz ● Maximum input current: 1.5 A |
AC input ● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz ● Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz ● Maximum input current: 3 A |
AC input ● Rated input voltage: 100 V AC to 240 V AC, 50 Hz to 60 Hz ● Maximum input voltage: 90 V AC to 264 V AC, 47 Hz to 63 Hz ● Maximum input current: 6 A |
Maximum output power |
Fixed power supply: 16 W |
Fixed power supply: 15.6 W |
Fixed power supply: 30 W |
Fixed power supply: 141 W |
Fixed power supply: 430 W |
PoE port |
Not supported |
Not supported |
Not supported |
Ports 1 to 8 support PoE/PoE+ (IEEE802.3af/at) power supply |
All RJ45 ports support PoE/PoE+ (IEEE802.3af/at) power supply |
PoE power cable pairs |
Not supported |
Not supported |
Not supported |
Mode A (1-2, 3-6 pairs) |
PoE output power |
Not supported |
Not supported |
Not supported |
Each port of ports 1 to 8 provides up to 30 W of power The maximum power is 125 W |
Each PoE port provides up to 30 W of power The maximum power is 370 W |
16 W |
15.6 W |
30 W |
16 W (without PoE load) 141 W (full PoE load) |
33 W (without PoE load) 403 W (full PoE load) |
Energy saving |
Energy Efficient Ethernet (EEE) |
Environment and reliability |
Temperature |
Humidity |
Altitude |
Operating altitude: –500 m to +5,000 m (–1640.42 ft. to +16404.20 ft.) Storage altitude: –500 m to +5,000 m (–1640.42 ft. to +16404.20 ft.) |
Mean time between failure (MTBF) |
200,000 hours (about 22 years) |
Fan |
Fanless |
Fanless |
2 x fixed fan modules |
1 x fixed fan module |
Heat dissipation |
Fanless design, natural heat dissipation |
Forced air cooling |
Acoustic noise |
Fanless |
Fanless |
27℃ (80.6°F): 40 dB |
USB hot swapping |
Supported |
Supported |
Supported |
Supported |
Supported |
Cable hot swapping |
Supported by all ports |
Fan monitoring |
Fanless design |
Fanless design |
Fan speed control and fan failure alarming |
Temperature monitoring |
Temperature monitoring, over-temperature alarming If the ambient temperature exceeds a certain value, the device will be reset. |
ESD |
Air discharge: 8 kV/15 kV Contact discharge: 6 kV/8 kV |
Surge protection |
Service port: 10 kV Power port: common mode 6 kV, differential mode 2 kV |
Certifications and regulatory compliance |
Safety regulation |
IEC 62368-1 |
EMC regulation |
EN 300386, EN 55032 Class A, EN 55035, EN IEC 61000-3-2, EN 61000-3-3, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-11 |
RoHS |
European RoHS Directive 2011/65/EU & Amendment(EU) 2015/863 |
Feature |
RG-S5000-E Series |
Ethernet switching |
802.3az EEE |
IEEE 802.1Q (4K VLANs) |
Port-based VLAN assignment |
IP service |
Static and dynamic ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
DNS client |
Neighbor Discovery (ND) |
IP routing |
OSPFv2 |
IGMP snooping v1/v2 |
IGMP fast leave |
MAC-based extended ACLs (ACLs based on source or destination MAC addresses) |
Expert ACLs |
IPv6 ACL |
ACL 80 |
Global ACLs |
Flow-based rate limiting at the ingress |
Port rate limiting |
Traffic classification based on 802.1p or DSCP priorities |
Eight queues on each port |
Rate limiting in each queue |
RADIUS and TACACS+ |
IEEE 802.1X authentication |
MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
SSHv1.5 and SSHv2.0 |
ICMPv6 |
Proxy ARP and ARP entry aging |
Hardware CPP and NFPP |
RLDP |
LACP |
Load balancing modes |
Rapid Link Detection Protocol (RLDP), Layer 2 link connectivity detection, and unidirectional link detection |
RSPAN |
sFlow (sFlow is a network detection technology based on packet sampling, which is mainly used for traffic statistics analysis in super-heavy network traffic scenarios) |
NTP (NTP client and NTP server) |
TFTP (TFTP client) |
SNMPv1/v2c/v3 |
CWMP |
SSH v1.5/v2.0 |
RG-S5000-10GT2MS-P-E and RG-S5000-24GT4MS-P-E: l IEEE 802.3af and 802.3at l Automatic and energy-saving power supply management mode l Uninterrupted power supply in hot start mode l Scheduled powering on or off PoE ports l Port priority |
Cloud |
WIS |
10 x 10/100/1000BASE-T ports with auto-negotiation, 2 x 1GE/2.5GE SFP ports, fixed single AC power supply |
24 x 10/100/1000BASE-T ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply |
48 x 10/100/1000BASE-T ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply |
10 x 10/100/1000BASE-T ports with auto-negotiation, 2 x 1GE/2.5GE SFP ports, fixed single AC power supply, ports 1 to 8 supporting PoE/PoE+ power supply, and maximum PoE output power of 125 W |
24 x 10/100/1000BASE-T ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, and maximum PoE output power of 370 W |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
GE-SFP-LX03-SM1310-BIDI-I |
GE-SFP-LX03-SM1550-BIDI-I |
2.5G-SFP-LX03-SM1310-BIDI-I |
2.5G-SFP-LX03-SM1550-BIDI-I |
