RG-PF2920-DPBOX-P Commutateurs - 1
RG-PF2920-DPBOX-P Commutateurs - 2
RG-PF2920-DPBOX-P Commutateurs - 3
RG-PF2920-DPBOX-P Commutateurs - 4
RG-PF2920-DPBOX-P, Single-Port Media Converter, Connecting to a Hybrid Cable in the Uplink Direction, with a PoE Port in the Downlink Direction
Indoor hybrid cable connection, fit for monitoring, wireless connection, and other scenarios on campus networks
Single-Port Media Converter RG-PF2920-DPBOX-P
The converter supports gigabit fiber-to-the-room, 2.5GE uplink, and hybrid cable connection. It applies to Ruijie Networks Power over Fiber (PoF) Solution and meets the requirements of monitoring, wireless connection, and other scenarios on campus networks.
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
1 x 1000M/2.5G SFP port
1 x GE SFP port
9.7 Mpps
SFP port
Rated current: 1.3 A
Rated current: 0.75 A
Leakage current to ground
≤ 3.5 mA
EEE
1 x downlink POE/POE+ port
Overall power consumption
Without PoE load: ≤ 15 W
With PoE full load: ≤ 75 W
Without PoE load: ≤ 3 W
Overall power (PoE+) ≤ 33 W
10% to 90% RH
10% to 90% RH
5% to 90% RH
5% to 95% RH
GB/T9254.1
GB/T9254.1
Safety standard
GB 4943.1
GB 4943.1
Dimension (W x D x H)
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
4K IEEE 802.1Q VLANs
Password protection
EEE
APD port sleeping
IoT MQTT
Syslog/Debug and SNTP
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
