RG-CS85-24SFP/8GT8XS-D Commutateurs - 1
RG-CS85-24SFP/8GT8XS-D Commutateurs - 2
RG-CS85-24SFP/8GT8XS-D Commutateurs - 3
RG-CS85-24SFP/8GT8XS-D Commutateurs - 4
RG-CS85-24SFP/8GT8XS-D Commutateurs - 5
RG-CS85-24SFP/8GT8XS-D Commutateurs - 6
RG-CS85-24SFP/8GT8XS-D Commutateurs - 7
RG-CS85-24SFP/8GT8XS-D Commutateurs - 8
RG-CS85-24SFP/8GT8XS-D Commutateurs - 9
RG-CS85-24SFP/8GT8XS-D Commutateurs - 10
RG-CS85-24SFP/8GT8XS-D Commutateurs - 11
RG-CS85-24SFP/8GT8XS-D Commutateurs - 12
RG-CS85-24SFP/8GT8XS-D 24-Port 1GE SFP Layer 3 Enterprise-Class Core or Aggregation Switch, 8-Port 10GE Uplink
  • Rich port types, 24 x 1GE SFP ports (with eight combo ports), and 8 x 1GE/10GE SFP+ ports for uplink
Layer 3 GE Core & Aggregation Switch RG-CS85-24SFP/8GT8XS-D
Aggregation switch for small and medium-sized campus networks, with eight 10G uplink optical ports for high-speed data transmission; 24 x 1GE optical ports (with eight combo ports) , providing high-speed network experience for long-distance services. Core switch for small and medium-sized enterprise networks, with high scalability, efficiency, and manageability, and device-level and link-level reliabilities for stable connectivity.
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
24 x 1GE SFP ports
CM85-4XS2CQ
M2SFAN I-F (pre-installed 2)
Module service port
CM85-4XS2CQ:
● 4 x 1GE/10GE SFP+ ports
● 2 x 40GE/100GE QSFP28 ports
1 x USB 3.0 port
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
Flash Memory
4 GB
1 GB
1 GB
1 GB
2 GB
Ingress: 7,000
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
Unit dimensions
(W x D x H)
440 mm x 340 mm x 44 mm
Shipping dimensions
(W x D x H)
593 mm x 497 mm x 192 mm
563 mm x 563 x mm 210 mm
4.4 kg
(9.70 lbs)
(9.48 lbs)
(9.92 lbs)
5.3 kg
(11.68 lbs)
5.7 kg
(12.57 lbs)
6.20 kg
(13.67 lbs)
6.62 kg
(14.59 lbs)
6.30 kg
(13.89 lbs)
7.70 kg
(16.98 lbs)
7.80 kg
(17.20 lbs)
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-PA150IB-F (AC input):
RG-CS85-48GT4XS-HPD
120 W (without PoE)
1,600 W (full PoE load)
● 2 x RG-PA600I-P-F: 740 W
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
3 x fixed fan modules
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85 Series
RG-CS85-24GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48SFP4XS-D
RG-CS85-48GT4XS-HPD
CM85-4XS2CQ
