RG-S6120-24XMG4XS4VS-UP-H Next-generation Multi-GE Switches
Diverse access rates: 10 Gbps/5 Gbps/2.5 Gbps/1 Gbps/100 Mbps
Multiple power modes: PoE/PoE+/PoE++
4 x 10GE SFP+ ports and 4 x 25GE SFP28 ports for uplink, enabling flexible networking and high-performance campus networks
  • 24 x 10GE/5GE/2.5GE/GE/100M Base-T Ethernet ports for access, 4 x 10GE SFP+ ports and 4 x 25GE SFP28 ports for uplink, meeting high-bandwidth campus network demands
Multi-GE Access
High-Power PoE Power Supply
Sound QoS Policies
Energy Saving
RG-S6110-24MG4VS-UP
RG-S6110-48MG4VS2QXS-UP
RG-S6120-48XMG4VS2QXS-UP-H
4 x 10GE/25GE SFP28 ports
1 x built-in power module
327 Mpps
625 Mpps
565 Mpps
982 Mpps
440 Gbps
840 Gbps
760 Gbps
1320 Gbps
Egress: 1,000
3.65 kg (8.05 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
1.2 GHz single-core processor
1 GB DDR4
1 GB flash memory
2 GB DDR4
1 GB flash memory
1 GB DDR4
1 GB flash memory
2 GB DDR4
1 GB flash memory
Without PoE: < 120 W
Full PoE load: < 370 W
Without PoE: < 240 W
Full PoE load: < 1,600 W
Full PoE load: < 1,650 W
Frequency: 50/60 Hz
RG-PA600I-P-F:
● Frequency: 50/60 Hz
90 V AC to 264 V AC
22.18 years
27.02 years
22.18 years
27.02 years
Front/Left-to-rear airflow
5% to 90% RH (non-condensing)
Maximum value < 78 dBA
6 kV
Software Specifications
RG-S6100 Series
Stateless Auto Configuration
GR for RIP, OSPF, and BGP
Ruijie Could-based management
Switches and Power Modules
RG-S6110-24MG4VS-UP
GE Optical Module
10GE Optical Modules
62.5 μm/125 μm: 33 m
50 μm/125 μm: 66 m
25GE Optical Modules
40GE Optical Modules
