Ruijie RG-N18000 Series can act as the core of unified authentication and gateway of the campus network to offer simplified network experience for users. As the centralized authentication gateway, the core device can achieve unified assignment of security policies. The access layer and aggregation layer are only responsible for Layer 2 forwarding. As the device maintenance is simpler, the performance capacity is no longer a bottleneck. The core layer device provides rich features, high performance and high reliability. The centralized management of network management policies facilitates security monitoring, network expansion and new service development. The Ruijie RG-N18000 Series supports multiple authentication modes such as Portal/ 802.1X. MAC. Different management modes and technologies will be deployed in different scenarios according to different user requirements of the campus network so as to provide targeted and high-availability technologies and solutions.
World’s Leading Cloud Network Core
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU/UIA/Product/Images/2020/2-15/202021528782575.png)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU//UIA/Product/Images/2014/7-8/20147842440707.jpg)
Advanced CLOS Architecture
Virtual Switch Unit 3.0 (VSU)
Virtual Switch Device (VSD)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU/UIA/Product/Images/2020/2-15/20202152986917.png)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU//UIA/Product/Images/2014/7-8/20147844364847.jpg)
Core Concepts
●Decoupling of control plane and forwarding plane → hardware / network unified abstraction & virtualization, ease of independent development
●Centralized control & distributed forwarding → convert the distributed protocol problem into algorithm problem
●Open programming interface → softwarization of hardware, programmable devices, scalable network features & higher flexibility
Solution Components
●Hardware Switching Devices:
Ruijie Newton 18000 and S6000 series platforms will fully support OpenFlow modular hardware switching
●SDN Controller RG-IONC
○MPLS L3 VPN service
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU/UIA/Product/Images/2020/2-15/20202152984211.png)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU//UIA/Product/Images/2014/7-8/20147845161956.jpg)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU/UIA/Product/Images/2020/2-15/202021530295769.png)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU//UIA/Product/Images/2014/7-8/20147845505407.jpg)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU/UIA/Product/Images/2020/2-15/202021530617355.png)
![](https://singapore-1312056779.cos.accelerate.myqcloud.com/FU//UIA/Product/Images/2014/7-8/20147846440633.jpg)
