RG-CS88-08 |
Power module |
2 |
Supervisor module slots |
2 |
Line card slot |
6 |
Switch fabric module slot |
2 (integrated with supervisor modules) |
Switching capacity |
9.6 Tbps |
Packet forwarding rate |
7200 Mpps |
MAC address table size |
● Number of global MAC addresses EB card: 64,000 DA card: 96,000 (default) and 288,000 (max.) FA card: 80,000 FB card: 96,000 ● Number of static MAC addresses EB card: 4,000 DA card: 10,000 FA card: 4,000 FB card: 40,000 |
EB card: 10,000 (default and recommended) DA card: underlay: 75,000; overlay: 0 (default and recommended) FA card: underlay: 30,000; overlay: 0 FB card: underlay: 50,000; overlay: 0 (default and recommended) |
EB card: 12,000 (default and recommended, shared with IPv6 routes) DA card: 12,000 (default and recommended, shared with IPv6 routes) FA card: 12,000 (default and recommended, shared with IPv6 routes) FB card: 134,000 (default and recommended, shared with IPv6 routes) |
EB card: 8,000 DA card: 16,000 FA card: 8,000 FB card: 16,000 |
EB card: 6,000 (shared with IPv4 routes) DA card: 6,000 (shared with IPv4 routes) FA card: 6,000 (shared with IPv4 routes) FB card: 50,000 (shared with IPv4 routes) |
EB card: 4,000 DA card: 8,000 FA card: 4,000 FB card: 8,000 |
● Ingress EB card: 3,500 DA card: 8,000 FA card: 5,000 FB card: 4,500 ● Egress EB card: 1,000 DA card: 1,000 FA card: 1,000 FB card: 2,000 |
442 mm x 465mm x 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.), 10 RU |
35.6 kg (78.48 lbs) |
● Supervisor module M7800C-CM: 1.0 GHz quad-core processor M7808C-CM II: 1.5 GHz quad-core processor ● Service module EA/EB card: 1.0 GHz quad-core processor DA/F card: 1.5 GHz quad-core processor |
Storage |
● Flash memory Supervisor module: M7800C-CM/M7808C-CM II: 8 GB Service module: EA card: 512 MB EB card: 512 MB DA/F card: 8 GB ● SDRAM Supervisor module: M7800C-CM: DDR3 4 GB M7808C-CM II: DDR4 4 GB Service module: EB card: DDR3 1 GB DA card: DDR4 1 GB F card: DDR4 2 GB |
Power and Consumption |
● Chassis RG-S7808C: < 176 W ● Supervisor module: M7808C-CM II: < 50 W ● Service module: M7800C-24SFP/12GT4XS-EB: < 85 W M7800C-36GT12SFP4XS-EB: < 80 W M7800C-48GT4XS-EB: < 70 W M7800C-48SFP4XS-EB: < 101 W M7800C-24GT24SFP4XS-EB: < 88 W M7800C-32XS4QXS-DA: < 210 W M7800C-24XT4QXS-DA: < 245 W M7800C-48GT-FA: < 75 W M7800C-48SFP-FA: < 95 W M7800C-48XS-FB: < 160 W M7800C-4CQ-FB: < 120 W M7800C-8CQ-FB: < 130 W |
Maximum output power |
● RG-PA600I-F: 600 W ● RG-PA1600I-F: 90 V AC to 180 V AC power:12,00 W;180 V AC to 264 V AC power: 1,600 W |
> 200,000 hours |
Primary Airflow |
● Supervisor module /Service module Right-to-rear airflow ● System power module Front-to-rear airflow |
0°C to 45°C (32°F to 113°F) |
Operating altitude |
–500 m to +5,000 m (–1640.42 ft. to +16404.20 ft.) |
Operating noise |
55.9 dB at the temperature of 27°C (80.6°F) 73.4 dB at the temperature of 45°C (113°F) |
Interface surge protection |
Power port: 6 kV Telecom port: 4 kV (MGMT port) |
RG-CS88 Series |
Feature |
Ethernet Switching |
Super VLAN, Private VLAN |
MPLS |
MPLS IPv6 |
MPLS L3VPN |
MPLS 6VPE |
MPLS MIB (RFC 1273, RFC 4265, and RFC 4382) |
IP Service |
Static and dynamic ARP |
DHCP client |
DHCP relay |
DHCP server |
DHCP snooping |
GRE tunnel |
Manual tunnel, automatic tunnel, and ISATAP tunnel for IPv6 |
IP Routing |
OSPFv2 and OSPFv3 |
IPv4/IPv6 IS-IS |
BGP4 and BGP4+ |
IPv4/IPv6 VRF |
Policy-based routing (PBR) |
GR |
EVPN |
IGMP v1/v2/v3 |
IGMP proxy |
IGMP snooping v1/v2/v3 |
IGMP fast leave |
PIM-DM, PIM-SM, and PIM-SSM |
PIM-SSM for IPv4 and IPv6 |
MLDv1 and MLDv2 |
MLD v1/v2 snooping |
Multicast static routing |
PIM-SMv6 |
ACL80 and IPv6 ACL |
Port traffic identification |
Port traffic rate limiting |
802.1p |
CAR |
AAA |
RADIUS authorization and accounting |
TACACS+ |
Portal authentication, RADIUS, and TACACS+ login authentication |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMP |
Port security |
DAI |
SAVI |
ARP spoofing prevention |
CPU Protect Policy (CPP) and NFPP |
Various attack defense functions, including NFPP and ARP anti-attack |
uRPF |
Login authentication and password security |
Unknown multicast packets are not sent to the CPU, and unknown unicast packets can be suppressed. |
Rapid Ethernet Uplink Protection (REUP) |
VRRP for the super-VLAN |
BFD |
1+1 redundancy for supervisor modules and fan modules, and N+M redundancy for power modules |
Hot swapping of components |
Hot patch and online installation of patches |
GR for OSPF/IS-IS/BGP |
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing |
SPAN, RSPAN, and ERSPAN |
sFLOW |
NTP |
SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
CWMP |
Cloud and SON |
Console/AUX Modem/Telnet/SSH2.0 CLI configuration |
Fault alarm and auto-recovery |
System operation logging |
RG-S7800C switches and supervisor engines |
RG-CS88-08 |
RG-CS88-08 switch, which can accommodate 6 service cards and 2 supervisor engines, and with 2 fans (Purchase at least one RG-PA600I-F/RG-PA1600I-F module.) |
CM88-CM |
CM88-CM new generation of high-performance engine. |
2.Power Modules and Fans
RG-PA600I-F |
Power module (support redundancy, AC, 600W) |
RG-PA1600I-F |
Power module (support redundancy, AC, 1600W) |
M08-FAN |
CS88-08 fan: Each M08-FAN tray consists of two fan modules and one fan monitoring card. It blows air to the outside for convection. (This is a default configuration for the switches.) |
3.Line Cards
Commercial-grade line cards |
CM88-48XS-H |
48 × 10GE optical ports (SFP+ and LC) |
CM88-8CQ-H |
8 × 100G Ethernet optical ports (QSFP28 and LC) |
CM88-48GT-H |
48 × GE electrical ports (RJ45) |
CM88-48SFP-H |
48 × GE optical ports (SFP+ and LC) |
