RG-N18012 Commutateurs - 1
RG-N18012 Commutateurs - 2
RG-N18012 Cloud Network Layer 3 Modular Core Switch with 12 Module Slots
Deployed in data centers, MANs, or campus networks (with or without data centers) scenarios according to business needs.
Virtual Switch Unit 3.0 (VSU)
Core Concepts
Solution Components
●Hardware Switching Devices:
●SDN Controller RG-IONC
○MPLS L3 VPN service
RG-N18007
RG-N18012
M07-FAN
2 x M12-FAN-R fan modules
System power: 4
PoE power: 2
System power: 6
PoE power: 2 (the power module must adapt to the PoE power frame)
Expansion slot
Supervisor module slots: 2
Line card slots: 5
CM slots: 2
Line card slots: 10
Switch fabric module slots: 4
Line card slot
8,900 Mpps
17,800 Mpps
12 Tbps
24 Tbps
Number of global MAC addresses:
● ED card: 128K (default) and 512K (max.)
● DC card: 96K (default) and 288K (max.)
● EH card: 136K (default) and 136K (max.)
Number of static MAC addresses: 10,000
● ED card: 170,000
● DC card: 75,000
● EH card: 170,000
● ED card: 170,000 (default)
● DC card: 75,000 (default)
● EH card: 170,000 (default)
ED card: 75,000 (default)
DC/EH card: 45,000 (default)
12,000 (default)
12,000 (default)
● ED card: 16,000 (default)
● DC card: 16,000 (default)
● EH card: 4,000 (default) and 8,000 (max.)
IPv6 hardware routing table size: 6,000 (default)
Size of the routing table with a subnet mask of 65 to 128 bits: 1,000 (default)
● ED card: 8,000 (default)
● DC card: 8,000 (default)
● EH card: 2,000 (default) and 4,000 (max.)
1,024
1,024
● Maximum number of ingress ACEs associated with an SVI, physical interface, or aggregate interface
ED card: 7,000
DC card: 8,000
EH card: 1,000
● Maximum number of egress ACEs associated with an SVI, physical interface, or aggregate interface: 1,000
ED card: 7,000
DC card: 8,000
EH card: 1,000
Stacking bandwidth
≥ 2.56 Tbps
442 mm x 598 mm x 352.8 mm (17.40 in. x 23.54 in. x 13.89 in.), 8 RU
442 mm x 725 mm x 708.4 mm (17.40 in. x 28.54 in. x 27.89 in.), 16 RU
30.2 kg (66.58 lbs)
105 kg (231.49 lbs)
Supervisor module:
● M18007-CM II: 1.0 GHz 32-core processor
Line card:
● ED card: 1.0 GHz quad-core processor
Supervisor module:
● M18012-CM II: 1.0 GHz 32-core processor
Line card:
● ED/DC: 1.0 GHz quad-core processor
Switch fabric module:
● M18012-FE-D I: 1.0 GHz quad-core processor
Flash memory and SDRAM
Flash memory:
● M18007-CM II/ED/DC card: 512 MB
SDRAM:
● M18007-CM II: DDRIII 16 GB
● ED/DC card: 1 GB
● 16XS2QXS: 4 GB
Flash memory:
● ED/DC/EH card: 512 MB
SDRAM:
● M18012-CM II: 16 GB
● M18012-FE-D I: DDRIII 1 GB
● ED/DC: 1 GB
● EF card: 2 GB
● 12CQ-EH/16XS2QXS: 4 GB
ED card: 5 MB
DC card: 16 MB
ED card: 5 MB
DC card: 16 MB
12CQ-EH: 16 MB
RG-PA1600I: 90 V to 180 V    Power: 1,200 W; 180 V to 264 V   Power: 1,600 W
RG-PD600I: –40 V to –75 V    Power: 600 W
210 V to 264 V
Power: 3,000 W
210 V to 264 V
Power: 3,000 W
RG-PA1600I: 100 V to 120 V, 200 V to 240 V, 50/60 Hz
RG-PA600I: 100 V to 120 V, 200 V to 240 V, 50/60 Hz
RG-PD600I: –48 V DC
RG-PD600I: –48 V DC
RG-PA1600I: 90 V to 264 V, 47 Hz to 63 Hz
RG-PA600I: 90 V to 264 V, 47 Hz to 63 Hz
RG-PD600I: –40 V DC to –75 V DC
Right-to-left airflow
Supervisor module and line card: right-to-left airflow
Power module: built-in fans for drawing air outward Front-to-rear airflow
Supervisor module and line card: air inlet at the front bottom and air outlet at the top back (M12-FAN-R)
0°C to 50°C (32°F to 122°F) with the height in the range of –500 m to +5,000 m (–1640.42 ft. to + 16404.20 ft.)
59.3 dB at the temperature of 35°C (95°F)
68.4 dB at the temperature of 50°C (122°F)
63.5 dB at the temperature of 35°C (95°F)
77.4 dB at the temperature of 50°C (122°F)
Port surge protection
All electrical ports: common mode 4 kV, differential mode 1 kV
6 kV
RG-N18000 Series
Edge Virtual Bridging (EVB)
Behavior control
URL audit
User locating
Central authentication
Concurrence of 90,000 IPv4 and IPv6 double stack users with an authentication capacity of 1,200 terminals per second
802.1X/Portal/MAC/IPoE authentication modes
Layer 2 Portal and Layer 3 Portal access authentication
Flow-based charging, flow control, and refined management
Gateway authentication
IEEE 802.1Q
Port-based, protocol-based, and IP subnet-based VLAN assignment
Basic QinQ, selective QinQ, and QinQ termination
DHCPv6 relay
IPv4/IPv6 IS-IS
Policy-based routing (PBR)
GRE tunnel
IPv6: manual tunnel, automatic tunnel, and ISATAP tunnel
IGMP v1/v2/v3 and IGMP proxy
IGMP snooping v1/v2/v3
PIM-SSM for IPv4
MLD and MLD proxy
Multicast forwarding in a VLAN and multicast replication between VLANs
Multicast load balancing
Standard ACL
Extended ACL
MAC extended ACL
Expert ACL
Applying ACLs globally
Port-based rate limit
IEEE 802.1p
ITU-T Y.1731
IPv4 VRRPv2/v3 and IPv6 VRRPv3
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/ MPLS/static routing
GR for OSPF/IS-IS/GBP
Independent switch fabric modules and supervisor modules to separate the forwarding plane from the control plane
N+M redundancy for power modules and fan modules
Passive backplane design, eliminating single point of failures
IP FRR
ISSU
*Virtual Switch Device (VSD)
SPAN and RSPAN
FTP, TFTP, and Xmodem
Multiple types of RMON groups, including event groups, alarm groups, history groups, and statistics groups
RMON Ethernet statistics, historical statistics, and alarms
Flow table analysis for all protocols
Configuring the controller IP address and port
Notification of port status changes to the controller
Fault alarm and automatic restoration
Data Center Manageability Interface (DCMI) used to remotely power on, power off, reset, and monitor the device
Many-to-one mirroring, one-to-many mirroring, and flow-based mirroring
VLAN mirroring
RG-N18007
RG-N18012
Supervisor Module
M18007-CM II
RG-N18007 2nd-generation supervisor module
M18012-CM II
RG-N18012 2nd-generation supervisor module
Power Module
RG-PA600I
RG-PD600I
RG-PA1600I
Switch Fabric Module
M18012-FE-D I
Line Card
M18000-44SFP4XS-ED
44 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC)
M18000-48GT-ED
M18000-24GT20SFP4XS-ED
24 x GE electrical ports (RJ45) + 20 x GE optical ports (SFP and LC) + 4 x 10GE optical ports (SFP+ and LC)
M18000-16XS2QXS-ED
16 x 10GE optical ports (SFP+ and LC) + 2 x 40GE optical ports (QSFP+ and MPO)
M18000-48XS-DC
M18000-24XS4QXS-DC
24 x 10GE optical ports (SFP+ and LC) + 4 x 40GE optical ports (QSFP+ and MPO)
M18000-12QXS-DC
12 x 40GE optical ports (QSFP+ and MPO)
M18000-12CQ-EH
12 x 100GE optical ports (QSFP28)
