Managed Switches
XS-S1960 Series Switches
XS-S1960 Switch Series is the newest access switch series for SMB market. XS-S1960-H Series Switches are fixed-configuration, Gigabit Ethernet switches that provide enterprise-class access switching for branch offices, the switches are managed switches offer advanced Layer 2 and basic Layer 3 features as well as High-power PoE Technology (IEEE 802.3bt). The switches adopt new web interface and can be managed at the Ruijie Cloud platform, provides easy device onboarding, configuration, monitoring, and troubleshooting.
Feature highlights of XS-S1960-H Switch Series:
Efficient management using Ruijie Cloud, Web-UI and command lines
Enterprise grade QoS, security and management features;
L3 features enables working in SMB campus core layer;
Unique security features like CPP and NFPP ensure network safety with smart counter measures;
Unique Smart+ features for CCTV networks.
Next-gen PoE Standard, 100% Full PoE on All
The XS-S1960 Series PoE switches support 802.3bt HPoE standards to offer up to 60-watt per port and a 370-watt high-power
budget. All of the access ports support POE+ output, to meet the connectivity needs of more power-hungry devices.
Conformal Coating Protection
With Conformal Coating for 2 years
No obvious corrosion was found after cleaning
Without Conformal Coating for 1 month
Rusted chip pins and resistor whiskers were found after cleaning
Special coating material painted on the PCBA
Excellent performance in being insulating,damp proof,dust proof, anti-corrosion, mold proof, and salt-spray resistant
Compliant with IEC60068-2-60 International Standard
Hybrid Management
  • Ruijie Cloud Management
    Managed at Ruijie Cloud platform, providing anytime anywhere mobile monitoring and troubleshooting, making the plug and play of network management devices possible.
  • Smart Web
    A fully functional built in Web-GUI allows operation to be intuitive and convenient.
  • Industry Standard CLI
    Industry Standard Command Line Interface (CLI) makes customer configuration and troubleshooting easier.
Enterprise-grade Stability & Security
Exemption from various internal and external threats
Devices able to operate stably at 7X24 hours
Application Scenario: SME Office
Advanced Layer 2 and Layer 3 basic features are supported which are necessary for an access or core switch of SME.
Application Scenario: ELV & Surveillance Monitoring
The XS-S1960 Series Switches are tailor-made for ELV & Surveillance Monitoring scenarios. Features like full PoE out, 6KV Lightning Protection,
Large Buffer and Non-blocking Architecture are essential for reliability and stability of 24x7 operation.
  • PoE+
    On All Ports
  • 6KV
  • Operation
    Temperature 0°C- 50℃
  • 12Mbit
    Large Buffer
  • Non-blocking
    Architecture
Ruijie Networks
